* | score: Fix simple timecounter support | Sebastian Huber | 2016-01-27 | 4 | -52/+56 |
| | | | | Close #2502. | ||||
* | remaining bsp.h: Fix by hand to LIBBSP_@CPU@_@BSP_FAMILY@_BSP_H | Joel Sherrill | 2015-07-16 | 3 | -6/+6 |
| | | | | These files were left after running the script in the previous patch. | ||||
* | Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guard | Joel Sherrill | 2015-07-16 | 18 | -36/+36 |
| | | | | | | | | | | | | | | | | | This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done | ||||
* | mcf5225x/clock/clock.c: Remove unused variable warning | Joel Sherrill | 2015-05-21 | 1 | -1/+0 |
* | mcf52235/clock/clock.c: Remove unused variable warning | Joel Sherrill | 2015-05-21 | 1 | -1/+0 |
* | mcf52235-testsuite.tcfg: Add syscall01 | Joel Sherrill | 2015-05-21 | 1 | -0/+1 |
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 9 | -62/+139 |
| | | | | Update #2271. | ||||
* | mrm332-testsuite.tcfg: Add fileio | Joel Sherrill | 2015-05-07 | 1 | -0/+1 |
* | ods68302-testsuite.tcfg: Add iosteam | Joel Sherrill | 2015-04-23 | 1 | -0/+1 |
* | mrm332-testsuite.tcfg: Add iostream and sptls02 | Joel Sherrill | 2015-04-23 | 1 | -0/+2 |
* | mcf5225x-testsuite.tcfg: Add iostream | Joel Sherrill | 2015-04-23 | 1 | -0/+1 |
* | ods68302-testsuite.tcfg: Add fileio | Joel Sherrill | 2015-04-03 | 1 | -0/+1 |
* | mrm332/console/sci.c: Make routines static | Joel Sherrill | 2015-03-24 | 1 | -4/+4 |
* | m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | mvme167/network/network.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -19/+21 |
* | mvme162/tod/tod.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -2/+2 |
* | mvme147s: Install z8530.h | Joel Sherrill | 2015-03-11 | 2 | -0/+13 |
| | | | | This was missed when the file was moved. | ||||
* | Move contents of libcsupport/include/zilog into libbsp/shared | Joel Sherrill | 2015-03-09 | 6 | -0/+39 |
| | | | | Only a few BSPs use this and it should not have been in libcsupport. | ||||
* | Move libcsupport/include/motorola/*.h to m68k/idp BSP | Joel Sherrill | 2015-03-09 | 4 | -0/+397 |
| | | | | | | | These header files were only used by one BSP and they are hardware dependent. The hardware dependency always made them bad candidates for where they were in the tree. But this fixes that. | ||||
* | mvme136.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 |
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 2 | -0/+2 |
* | mcf5206elite/include/i2c.h: Fix spelling error | Joel Sherrill | 2015-01-23 | 1 | -1/+1 |
* | bsp/mcf5206elite: Remove <i2c.h> inlude in <bsp.h> | Sebastian Huber | 2015-01-14 | 2 | -3/+1 |
| | | | | This prevents a compile-time error in libtests/i2c01. | ||||
* | mcf5225x-testsuite.tcfg: Add fileio | Joel Sherrill | 2014-12-15 | 1 | -0/+1 |
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 24 | -24/+24 |
* | libmisc: More useful default configuration | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
| | | | | | | | | | | | The dummy.c was a de-facto default configuration. Rename it to default-configuration.c. Use unlimited objects and the stack checker. This makes it easier for new RTEMS users which will likely use this file if they just work with the usual main() function as the application entry point. Provide proper arguments for main() using the BSP command line. Add spare user extensions and drivers. Do not initialize the network by default. Delete bspinit.c. | ||||
* | m68k/mcf5235: GCC 4.9.2 generates invalid code for Init5235. | Chris Johns | 2014-12-01 | 3 | -13/+26 |
| | | | | | | | Move the vector table copy out of the Init5235 source to avoid stipping the GCC bug. Fixes #2204. | ||||
* | bsps: Move extern "C" to not cover includes | Sebastian Huber | 2014-10-23 | 20 | -80/+81 |
| | | | | Some includes may use C++ and this conflicts if surrounded extern "C". | ||||
* | m68k/mrm332: Fix warnings | Joel Sherrill | 2014-10-20 | 1 | -8/+5 |
* | m68k/mcf5329: Fix warnings | Joel Sherrill | 2014-10-20 | 2 | -0/+6 |
* | m68k/mcf5235: Fix warnings | Joel Sherrill | 2014-10-20 | 1 | -0/+5 |
* | m68k/mcf5225x: Fix warnings | Joel Sherrill | 2014-10-20 | 2 | -0/+6 |
* | m68k/mcf52235: Fix warnings | Joel Sherrill | 2014-10-20 | 2 | -0/+6 |
* | m68k/idp: Fix warnings | Joel Sherrill | 2014-10-20 | 1 | -0/+1 |
* | m68k/gen68360: Fix warnings | Joel Sherrill | 2014-10-20 | 2 | -3/+13 |
* | m68k/csb360: Fix warnings | Joel Sherrill | 2014-10-20 | 3 | -70/+69 |
* | m68k/av5282: Fix warning | Joel Sherrill | 2014-10-19 | 3 | -49/+58 |
* | m68k/mrm332: Move include of <rtems/m68k/sim.h> | Joel Sherrill | 2014-10-19 | 2 | -1/+1 |
| | | | | | | This file defines at least the POW() macro which pollutes the public name space and causes warnings in at least the paranoia sample application. | ||||
* | m68k/mcf5329/startup/init5329.c: Fix warning | Joel Sherrill | 2014-10-19 | 1 | -2/+1 |
* | m68k/mcf52235/startup/init52235.c: Fix warning | Joel Sherrill | 2014-10-19 | 1 | -2/+1 |
* | gen68302/console: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -79/+26 |
* | m68k/mrm332/console/sci.c: Fix missing variable error introduced by earlier ↵ | Joel Sherrill | 2014-10-19 | 1 | -3/+0 |
| | | | | patch | ||||
* | mcf5206 libcpu and mcf5206elite: Fix warnings | Joel Sherrill | 2014-10-19 | 5 | -481/+463 |
* | m68k/mvme147: Fix warnings | Joel Sherrill | 2014-10-19 | 3 | -64/+17 |
* | m68k/mvme167: Fix warnings | Joel Sherrill | 2014-10-19 | 2 | -10/+26 |
* | m68k/shared and sim68000: Fix warnings | Joel Sherrill | 2014-10-19 | 5 | -32/+29 |
* | m68k/mvme162: Fix warnings | Joel Sherrill | 2014-10-19 | 9 | -947/+918 |
* | mcf5282: Move cache to libcpu and update av5282 and uC5282 BSPs | Joel Sherrill | 2014-10-16 | 4 | -214/+36 |
* | m68k/gen68340: Fix warnings | Joel Sherrill | 2014-10-16 | 6 | -591/+544 |
* | Move CPU cache support from mcf5225x BSP to libcpu | Joel Sherrill | 2014-10-16 | 2 | -24/+1 |
