2010-08-03 | 2010-08-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 8 | -5/+24 | |
* console/console.c: Add BSP_poll_char. | |||||
2010-08-03 | 2010-08-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -2/+12 | |
* console/debugio.c: Add BSP_poll_char. | |||||
2010-08-03 | 2010-08-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -638/+631 | |
* console/console.c: Add BSP_poll_char. Reformat. | |||||
2010-06-22 | 2010-06-22 Chris Johns <chrisj@rtems.org> | Chris Johns | 2 | -1/+5 | |
* startup/m68k-stub.c: PR 1539. Fix buffer overrun. | |||||
2010-06-21 | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -6/+10 | |
* README: Remove more ITRON references. | |||||
2010-06-14 | 2010-06-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* startup/bspclean.c: Spelling. | |||||
2010-05-04 | 2010-05-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -1/+8 | |
* include/bsp.h: Add BSP_SMALL_MEMORY. * startup/linkcmds: Wildcard on .data so C++ links. | |||||
2010-04-30 | 2010-04-30 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -3/+6 | |
* include/bsp.h: Add BSP_SMALL_MEMORY. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -4/+10 | |
* startup/bsppredriverhook.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -3/+7 | |
* startup/m68k-stub.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -2/+10 | |
* timer/timer.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -6/+13 | |
* startup/bspclean.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -4/+8 | |
* startup/bspclean.c, timer/timer.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -3/+6 | |
* startup/init5235.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -2/+7 | |
* console/leds.c, timer/timer.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -1/+7 | |
* console/m340uart.c, startup/init68340.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -4/+11 | |
* startup/init68360.c, timer/timer.c: Remove warnings. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -8/+12 | |
* startup/bspclean.c, startup/bspstart.c: Remove warnings. | |||||
2010-04-27 | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -16/+5 | |
* startup/init5206e.c: Remove warnings. | |||||
2010-04-27 | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -19/+9 | |
* startup/init5272.c: Remove warnings. | |||||
2010-04-27 | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -112/+116 | |
* network/network.c: Remove warnings. | |||||
2010-04-27 | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -64/+105 | |
* network/network.c, startup/bspstart.c: Remove warnings. hwaddr handling changed to avoid use of unitialized variable. | |||||
2010-04-27 | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 4 | -65/+72 | |
* network/network.c, startup/bspclean.c, startup/init5282.c: Remove warnings. | |||||
2010-04-26 | * startup/bspstart.c: Clean up some warnings. | Eric Norum | 3 | -4/+10 | |
* network/network.c: Fix up full/half duplex printout and some warnings. | |||||
2010-04-26 | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* network/network.c: Fix warning. | |||||
2010-04-26 | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -4/+8 | |
* console/console.c: Fix prototypes. | |||||
2010-04-18 | 2010-04-18 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 3 | -0/+16 | |
* .cvsignore, include/.cvsignore: New files. | |||||
2010-04-13 | 2010-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* console/console.c: Fix broken comment formatting. | |||||
2010-04-13 | Fix broken comment format. | Ralf Corsepius | 1 | -2/+1 | |
2010-04-11 | 2010-04-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -0/+6 | |
* console/debugio.c: Include <unistd.h>. | |||||
2010-04-08 | 2010-04-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -5/+9 | |
* start/start.S: Spacing. | |||||
2010-04-05 | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2 | -0/+6 | |
* acinclude.m4: Add mcf5225x BSP. | |||||
2010-04-05 | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2 | -0/+5 | |
* configure.ac: Add mcf5225x BSP. | |||||
2010-04-05 | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 19 | -0/+2218 | |
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init, preinstall.am, clock/clock.c, console/console.c, console/debugio.c, include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5225x.c, startup/linkcmds, timer/timer.c: New files. | |||||
2010-03-27 | get desired clock rate for proper source | Thomas Doerfler | 2 | -2/+8 | |
2010-03-04 | 2010-03-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* README: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it. | |||||
2010-02-25 | combine all checks for missing MAC address | Thomas Doerfler | 4 | -21/+24 | |
enable FPU, if POSIX init task present explicitly disable all edge port interrupts | |||||
2009-12-17 | adapted to new prototype for *_write function | Thomas Doerfler | 28 | -90/+154 | |
2009-12-14 | get vital data from dBUG monitor for COBRA5475 board | Thomas Doerfler | 4 | -2/+37 | |
2009-12-08 | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+7 | |
* startup/init5206e.c: Make prototype of CopyDataClearBSSAndStart global. | |||||
2009-12-08 | 2009-12-08 Eric Norum <wenorum@lbl.gov> | Joel Sherrill | 2 | -15/+13 | |
PR 1479/bsps * fatal/bspfatal.c: Complete strcat conversion. | |||||
2009-12-08 | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* include/i2c.h (i2c_transfer_done): Fix type mismatch. | |||||
2009-12-08 | (i2c_transfer_done): Fix type mismatch. | Ralf Corsepius | 1 | -1/+1 | |
2009-12-08 | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* tod/ds1307.c (ds1307_set_time): Fix broken prototype. | |||||
2009-12-08 | (ds1307_set_time): Fix broken prototype. | Ralf Corsepius | 1 | -1/+1 | |
2009-11-29 | Whitespace removal. | Ralf Corsepius | 51 | -758/+758 | |
2009-11-28 | Whitespace removal. | Ralf Corsepius | 23 | -27/+27 | |
2009-11-16 | 2009-11-16 Alan Cudmore <alan.p.cudmore@nasa.gov> | Joel Sherrill | 2 | -1/+6 | |
* startup/init5235.c: Add volatile to prevent newer gcc versions from optimizing away. | |||||
2009-11-03 | 2009-11-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* startup/init548x.c: Comment out junk from end of #endif. | |||||
2009-11-03 | Regenerate. | Ralf Corsepius | 1 | -9/+1 | |
