warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* startup/bspstart.c: Fix clock code on qemu. Also ensure UART is
initialized early for printk.
PR 1738/bsps
* clock/clock.c, include/bsp.h, network/network.c: system clock driver
programs the PIT w/o assuming the CPU clock frequency being a power
of two.
PR 1738/bsps
* README, startup/bspstart.c, startup/linkcmds: Add support for dynamic
clock speed determination. This algorithm is described in the README
file. The output of the RTEMS Timing Tests was moved to TIMES to
signicantly shrink the README.
* TIMES: New file.
* clock/clock.c, startup/bspstart.c, startup/init5282.c:
* timer/timer.c: Include <rtems/btimer.h>.
* network/network.c: Remove warnings.
* network/network.c, startup/bspclean.c, startup/init5282.c: Remove
warnings.
* network/network.c: Fix up full/half duplex printout and some warnings.
* start/start.S: Spacing.
* startup/bspstart.c: Add missing prototype.
* make/custom/uC5282.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/uC5282.cfg: New (relocated from /make/custom).
