for details.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Rename
existing bsp_reset() to bsp_sysReset() since the prototype did not
match the standard one. Add standard bsp_reset().
* startup/bspreset.c: New file.
* Makefile.am, startup/bspstart.c, startup/linkcmds: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
use of bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Move interrupt_stack_size field from
CPU Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* Makefile.am: Add preinstall.am.
