* console/debugio.c: Include <unistd.h>.
* make/custom/sim68000.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simcpu32.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/sim68000.cfg: New (relocated from /make/custom).
* make/custom/simcpu32.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac, console/conscfg.c: Add CONSOLE_USE_INTERRUPTS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* console/debugio.c, startup/bsppredriverhook.c: New files.
* startup/bspstart.c: Removed.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/clockdrv.c, startup/bspstart.c: Add missing prototypes.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* startup/bspstart.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* startup/bspstart.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* startup/linkcmds: Handle .data.* sections
* bsp_specs: Remove qrtems_debug.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* startup/linkcmds: Add sections required by newer gcc versions.
* Makefile.am: Add preinstall.am.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
Also extended RAM section since this is for a simulator
