path: root/c/src/lib/libbsp/m68k/sim68000 (follow)
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-063-2/+7
| | | | | * startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h. * startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-1/+1
| | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-032-7/+5
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-302-1/+7
| | | | | | * start/start.S: Use __mcpu32__ instead of mcpu32 and change sense of conditional so cpu32 does not attempt to use 68000 style interrupt vectoring.
* 2001-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-174-2/+39
| | | | | | | | * timer: New subdirectory. * timer/Makefile.am: New file. * timer/.cvsignore: New file. * Makefile.am: Modified to reflect above. * configure.ac: Ditto.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+34
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-33/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-1/+5
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-2/+7
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-192-1/+6
| | | | | * start/start.S: Reverse sense of conditional compilation so the code will compile for a cpu32.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-185-9/+24
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-1/+5
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+9
| | | | | * start/start.S: Added space for vectors on CPU32 configuration. * startup/bspstart.c: Fixed typo.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-192-1/+8
| | | | | | * startup/linkcmds: Set _VBR to 0 to indicate that the vectors are in RAM not ROM. Thanks to Juan Zamorano <jzamora@fi.upm.es> for debugging this.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-8/+45
| | | | | * README, sim68000.setup, clock/clockdrv.c: Modified to add support for timer as clock tick source. Compiles but untested.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-0/+12
| | | | | | * start/start.S, startup/bspstart.c: Not functional for CPU32 but hopefully will compile now and give a warning saying that the CPU32 variant needs work.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-4/+10
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+6
* 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-09-292-0/+46
| | | | | | * startup/linkcmds: Added lines so DWARF debug information would be available. Otherwise gdb complains that the offsets for the debug info are incorrect and doesn't load the files.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-056-4/+14
| | | | | * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include compile.am
* Compiles now.Joel Sherrill2000-08-012-3/+2
* Added sim68000 BSP for the BSVC simulator. This BSP includes theJoel Sherrill2000-08-0125-0/+1178
alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development.
