* console/conscfg.c, include/bsp.h, startup/bspstart.c,
startup/spurious_assistant.c: URL for license changed.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
