path: root/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg (follow)
* Use $(EXEEXT) [defaults to "exe"] to generate binariesNick Withers2013-08-091-1/+1
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-211-3/+0
| | | | | * make/custom/sim68000.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/simcpu32.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+25
* make/custom/sim68000.cfg: New (relocated from /make/custom). * make/custom/simcpu32.cfg: New (relocated from /make/custom).
