Conflicts:
* include/bsp.h:
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c: Convert to using c99 fixed size types.
Reflect changes to bsp.am.
* console/conscfg.c, include/bsp.h, startup/bspstart.c,
startup/spurious_assistant.c: URL for license changed.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
