PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
for libchip serial drivers.
* console/debugio.c: Include <unistd.h>.
* configure.ac, console/conscfg.c: Add CONSOLE_USE_INTERRUPTS.
* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* console/debugio.c, startup/bsppredriverhook.c: New files.
* startup/bspstart.c: Removed.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c: Convert to using c99 fixed size types.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use
automake compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* console/conscfg.c, include/bsp.h, startup/bspstart.c,
startup/spurious_assistant.c: URL for license changed.
* console/conscfg.c, startup/bspstart.c: Removed warnings.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
