* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c: Convert to using c99 fixed size types.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use
automake compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* README, sim68000.setup, clock/clockdrv.c: Modified to add
support for timer as clock tick source. Compiles but untested.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
