* | m68k/shared and sim68000: Fix warnings | Joel Sherrill | 2014-10-19 | 2 | -20/+11 |
* | m68k/mvme162: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -3/+3 |
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 1 | -1/+3 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 6 | -6/+6 |
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 1 | -0/+8 |
* | libbsp/m68k: Add doxygen to m68k shared files. | Szkocsovszki Zsolt | 2013-12-26 | 3 | -4/+45 |
* | bsps/m68k: Add and use linkcmds.base | Sebastian Huber | 2013-12-16 | 2 | -0/+397 |
* | m68k: refactored shared/start.S to shared/start/start.S | Daniel Ramirez | 2013-12-03 | 1 | -0/+0 |
* | m68k/shared/start.S: Fix spacing | Joel Sherrill | 2013-09-16 | 1 | -1/+1 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -29/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 5 | -10/+0 |
* | m68k: use shared setvec.c | Gedare Bloom | 2012-04-16 | 1 | -37/+0 |
* | m68k: replace m68k_isr with rtems_isr | Gedare Bloom | 2012-04-16 | 1 | -2/+2 |
* | 2011-07-12 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-07-12 | 2 | -9/+6 |
| | | | | | * shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR after RTC replaced. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 1 | -29/+29 |
| | | | | | * shared/gdbstub/m68k-stub.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -1/+1 |
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 1 | -7/+2 |
| | | | | * shared/start/start.S: Update for boot_card command line change. | ||||
* | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-16 | 1 | -44/+0 |
| | | | | * shared/m68kbspgetworkarea.c: Removed. | ||||
* | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-16 | 2 | -68/+2 |
| | | | | | | | * shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * shared/m68kpretaskinghook.c: Removed. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 1 | -2/+2 |
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 1 | -5/+8 |
| | | | | | * shared/m68kbspgetworkarea.c: Move extern of global symbols from linkcmds outside function. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-19 | 1 | -1/+1 |
* | Changed bsp_get_workarea() to bsp_get_work_area() and | Thomas Doerfler | 2008-07-24 | 1 | -8/+11 |
| | | | | added support for an optional separate heap area. | ||||
* | 2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Chris Johns | 2008-06-11 | 2 | -1/+5 |
| | | | | | | | * shared/m68kbspgetworkarea.c: Fix extern type to RamSize. * shared/m68kpretaskinghook.c: Do not handle the RAM allocation if the BSP is handling it. * acinclude.m4: Add the mcf52235 BSP. | ||||
* | 2008-05-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-05-15 | 2 | -5/+38 |
| | | | | | | | | | | | | | | | * shared/m68kpretaskinghook.c: Add capability for bootcard.c BSP Initialization Framework to ask the BSP where it has memory for the RTEMS Workspace and C Program Heap. These collectively are referred to as work area. If the BSP supports this, then it does not have to include code to split the available memory between the two areas. This reduces the amount of code in the BSP specific bspstart.c file. Additionally, the shared framework can dirty the work area memory. Until most/all BSPs support this new capability, if the BSP supports this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When the transition is complete, this autoconf macro can be removed. * shared/m68kbspgetworkarea.c: New file. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 1 | -2/+1 |
| | | | | | | * shared/m68kpretaskinghook.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | ||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 1 | -1/+0 |
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -94/+0 |
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 2 | -3/+8 |
| | | | | | * m68kpretaskinghook.c: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-01-28 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2005-01-31 | 1 | -0/+4 |
| | | | | * m68kpretaskinghook.c: Work around agressive optimizing compilers. | ||||
* | New BSP for Arcturus uCDIMM ColdFire 5282. | Eric Norum | 2005-01-28 | 1 | -7/+11 |
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 4 | -23/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 7 | -161/+161 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -4/+0 |
* | * start.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 2 | -1/+5 |
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -1/+5 |
| | | | | * bspspuriousinit.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -4/+8 |
| | | | | * m68k-stub.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-03-05 | 2 | -3/+9 |
| | | | | | | PR 505/bsps * setvec.c: Rework to remove punned pointer warning generated by gcc 3.3 and newer. | ||||
* | Remove .cvsignore | Ralf Corsepius | 2004-01-28 | 1 | -2/+0 |
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent) | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -2/+1 |
* | 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-10 | 2 | -1/+6 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-04 | 3 | -10/+12 |
| | | | | | | * Makefile.am: merge-in gdbstub/Makefile.am. Add stray files bspspuriousinit.c, m68000spurious.c. * gdbstub/Makefile.am: Remove. | ||||
* | 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-03 | 2 | -1/+7 |
| | | | | | * Makefile.am: Cosmetics. Add mvme/mvme16x_hw.h. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 7 | -6/+11 |
| | | | | | * bspspuriousinit.c, m68000spurious.c, m68kpretaskinghook.c, setvec.c, start.S, mvme/mvme16x_hw.h: URL for license changed. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 2 | -2/+2 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 4 | -3/+11 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-15 | 2 | -2/+4 |
| | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -5/+9 |
| | | | | * m68k-stub.c: Corrected typos. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -76/+81 |
| | | | | * m68k-stub.c: Fixed warnings about multi-line strings in asm. |
