* bspspuriousinit.c, m68000spurious.c: Include rtems/bspIo.h
instead of bspIo.h.
* shared/bsppretaskinghook.c: assoc.h, error.h, libio_.h, libio.h,
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we
can check which BSP this is being used with.
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
converted to automake.
and memory layout. Next step is to share the same bsp_pretasking_hook.
that converts the libbsp/i386 subdirectory to full automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
implementation as all m68k BSPs.
