* shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR
after RTC replaced.
* shared/gdbstub/m68k-stub.c:
* shared/start/start.S: Update for boot_card command line change.
* shared/m68kbspgetworkarea.c: Removed.
* shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its
own file and rely on BSP Framework to perform more initialization.
Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* shared/m68kpretaskinghook.c: Removed.
* shared/m68kbspgetworkarea.c: Move extern of global symbols from
linkcmds outside function.
added support for an optional separate heap area.
* shared/m68kbspgetworkarea.c: Fix extern type to RamSize.
* shared/m68kpretaskinghook.c: Do not handle the RAM allocation if
the BSP is handling it.
* acinclude.m4: Add the mcf52235 BSP.
* shared/m68kpretaskinghook.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can dirty the work area memory.
Until most/all BSPs support this new capability, if the BSP supports
this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from
its configure.ac. When the transition is complete, this autoconf
macro can be removed.
* shared/m68kbspgetworkarea.c: New file.
* shared/m68kpretaskinghook.c: Eliminate copies of the Configuration
Table. Use the RTEMS provided accessor macros to obtain configuration
fields.
* m68kpretaskinghook.c: Correct type of symbols from linkcmds to
compile with gcc 4.x.
* m68kpretaskinghook.c: Work around agressive optimizing compilers.
* bspspuriousinit.c: Convert to using c99 fixed size types.
* m68k-stub.c: Convert to using c99 fixed size types.
PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* Makefile.am: Cosmetics.
* Makefile.am: merge-in gdbstub/Makefile.am.
Add stray files bspspuriousinit.c, m68000spurious.c.
* gdbstub/Makefile.am: Remove.
Add mvme/mvme16x_hw.h.
* bspspuriousinit.c, m68000spurious.c, m68kpretaskinghook.c, setvec.c,
start.S, mvme/mvme16x_hw.h: URL for license changed.
* m68k-stub.c: Corrected typos.
* m68k-stub.c: Fixed warnings about multi-line strings in asm.
* m68k-stub.c: Eliminated multi-line asm statements for gcc 3.x.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory.
* gdbstub: New directory.
* Makefile.am: Modified to reflect above.
* Added m68k serial stub that is thread aware.
* ChangeLog, gdb_if.h, m68k-stub.c, Makefile.am: New files.
* include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h.
