* | 2000-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-15 | 1 | -0/+2 |
| | | | | | * include/mvme16x_hw.h: Include rtems/score/targopts.h so we can check which BSP this is being used with. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -14/+34 |
| | | | | | | | * clock/Makefile.am, console/Makefile.am, consolex/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include compile.am | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
* | Split out items shared with mvme167. | Joel Sherrill | 2000-08-02 | 1 | -0/+244 |
* | Added sim68000 BSP for the BSVC simulator. This BSP includes the | Joel Sherrill | 2000-08-01 | 2 | -0/+122 |
| | | | | | alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -8/+14 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 1 | -4/+1 |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | ||||
* | All m68k BSPs now build with new ELF style linkcmds. | Joel Sherrill | 2000-01-13 | 1 | -1/+0 |
* | Made sweep of changes to get all BSPs to the same point on the linkcmds | Joel Sherrill | 2000-01-13 | 2 | -2/+64 |
| | | | | and memory layout. Next step is to share the same bsp_pretasking_hook. | ||||
* | Patch rtems-rc-20000104-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-12 | 1 | -3/+3 |
| | | | | that converts the libbsp/i386 subdirectory to full automake. | ||||
* | Patch rtems-rc-20000104-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -0/+12 |
| | | | | | | | | | | | | | | | | | that converts the m68k directory to automake. NOTE: This one is fully tested by building *all* bsps with ../../rtems-rc-20000104/configure \ --target=m68k-rtems \ --prefix=/tmp/rtems \ --enable-cxx \ --disable-posix \ --enable-rdbg \ --disable-networking \ --enable-maintainer-mode \ --enable-multiprocessing \ --disable-tests make | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 2 | -4/+2 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+153 |
| | | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | ||||
* | Fixed typo. | Joel Sherrill | 1998-03-20 | 1 | -1/+1 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 1997-04-15 | 1 | -0/+39 |
implementation as all m68k BSPs. |
