2003-12-10 | 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+6 | |
* Makefile.am: Cosmetics. | |||||
2003-12-04 | 2003-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -10/+12 | |
* Makefile.am: merge-in gdbstub/Makefile.am. Add stray files bspspuriousinit.c, m68000spurious.c. * gdbstub/Makefile.am: Remove. | |||||
2003-12-03 | 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+7 | |
* Makefile.am: Cosmetics. Add mvme/mvme16x_hw.h. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 7 | -6/+11 | |
* bspspuriousinit.c, m68000spurious.c, m68kpretaskinghook.c, setvec.c, start.S, mvme/mvme16x_hw.h: URL for license changed. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 2 | -2/+2 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -3/+11 | |
Makefile.am: Reflect having moved automake. | |||||
2002-11-15 | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+4 | |
* Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+9 | |
* m68k-stub.c: Corrected typos. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -76/+81 | |
* m68k-stub.c: Fixed warnings about multi-line strings in asm. | |||||
2002-07-01 | 2002-07-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -45/+49 | |
* m68k-stub.c: Eliminated multi-line asm statements for gcc 3.x. | |||||
2002-06-27 | 2002-06-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+10 | |
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k support to the shared gdb stub glue thus adding a directory. * gdbstub: New directory. * Makefile.am: Modified to reflect above. | |||||
2002-06-27 | 2002-06-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Joel Sherrill | 5 | -0/+1512 | |
* Added m68k serial stub that is thread aware. * ChangeLog, gdb_if.h, m68k-stub.c, Makefile.am: New files. | |||||
2002-04-08 | 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -1/+4 | |
2002-01-06 | 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -2/+7 | |
* bspspuriousinit.c, m68000spurious.c: Include rtems/bspIo.h instead of bspIo.h. | |||||
2000-11-01 | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+9 | |
* shared/bsppretaskinghook.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this. | |||||
2000-09-15 | 2000-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+2 | |
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we can check which BSP this is being used with. | |||||
2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -14/+34 | |
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include compile.am | |||||
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
2000-08-02 | Split out items shared with mvme167. | Joel Sherrill | 1 | -0/+244 | |
2000-08-01 | Added sim68000 BSP for the BSVC simulator. This BSP includes the | Joel Sherrill | 2 | -0/+122 | |
alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 2 | -8/+14 | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+2 | |
adds .cvsignore. | |||||
2000-01-31 | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 1 | -4/+1 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | |||||
2000-01-13 | All m68k BSPs now build with new ELF style linkcmds. | Joel Sherrill | 1 | -1/+0 | |
2000-01-13 | Made sweep of changes to get all BSPs to the same point on the linkcmds | Joel Sherrill | 2 | -2/+64 | |
and memory layout. Next step is to share the same bsp_pretasking_hook. | |||||
2000-01-12 | Patch rtems-rc-20000104-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -3/+3 | |
that converts the libbsp/i386 subdirectory to full automake. | |||||
2000-01-10 | Patch rtems-rc-20000104-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+12 | |
that converts the m68k directory to automake. NOTE: This one is fully tested by building *all* bsps with ../../rtems-rc-20000104/configure \ --target=m68k-rtems \ --prefix=/tmp/rtems \ --enable-cxx \ --disable-posix \ --enable-rdbg \ --disable-networking \ --enable-maintainer-mode \ --enable-multiprocessing \ --disable-tests make | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 2 | -4/+2 | |
1998-12-14 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1 | -0/+153 | |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
1998-03-20 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. | |||||
1997-04-15 | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 1 | -0/+39 | |
implementation as all m68k BSPs. |
