path: root/c/src/lib/libbsp/m68k/shared/mvme/mvme16x_hw.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-274/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-12-26libbsp/m68k: Add doxygen to m68k shared files.Szkocsovszki Zsolt1-2/+14
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-07-122011-07-12 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-4/+6
* shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR after RTC replaced.
2006-03-17Remove eof include fileRalf Corsepius1-1/+0
2004-04-21Remove duplicate white lines.Ralf Corsepius1-3/+0
2004-04-21Remove stray white spaces.Ralf Corsepius1-4/+4
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* bspspuriousinit.c, m68000spurious.c, m68kpretaskinghook.c, setvec.c, start.S, mvme/mvme16x_hw.h: URL for license changed.
2002-04-082002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h.
2000-09-152000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+2
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we can check which BSP this is being used with.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-14/+34
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include compile.am
2000-08-02Split out items shared with mvme167.Joel Sherrill1-0/+244
