* include/bsp.h: Replace stringification madness to pick up bare.h
(Doesn't work with gcc >= 3.3) with a somewhat cleaner madness.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
startup/bspclean.c, startup/bspstart.c, timer/timer.c: URL for
license changed.
* start/debugreset.S, start/reset.S: Removed incorrect statement about
copyright assignment.
* startup/Makefile.am: Remove USE_INIT_FINI.
PR414 - Fixed the global interupt vector register.
Linker command file to have the boot code in the first 8K.
The chip select remap needed to be volatile.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/m68k-stub.c: Removed typos.
* startup/m68k-stub.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* start/Makefile.am: Pick up rest of Ralf'f changes and use
cp not make-rel since there is no point in this case.
* start/debugreset.S: Rights were not assigned.
* start/reset.S: Add ifdef to avoid core dump until Chris can
track it down.
* start/cpuboot.c: Moved to startup.
* startup/Makefile.am: Account for above.
* startup/Makefile.am: Remove -DGDB_MONITOR_ACTIVE (Not used
anywhere).
Add ODS60302_DEBUG conditional.
* include/bsp.h: Fix broken bsp_cat macros (Not compliant to gcc31).
* configure.ac: Add --enable-ods60302-debug.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
* configure.in: Remove.
