* start/Makefile.am: Pick up rest of Ralf'f changes and use
cp not make-rel since there is no point in this case.
* start/debugreset.S: Rights were not assigned.
* start/reset.S: Add ifdef to avoid core dump until Chris can
track it down.
* start/cpuboot.c: Moved to startup.
* startup/Makefile.am: Account for above.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
that converts the libbsp/i386 subdirectory to full automake.
