* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 1 | -4/+0 |
| | | | | * make/custom/ods68302.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -0/+35 |
* make/custom/ods68302.cfg: New (relocated from /make/custom). |
