* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* start/reset.S: Remove cat(). Add EXPAND(). Make EXCEPTION_HANDLER
ANSI-C compliant.
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
start/Makefile.am, startup/Makefile.am, timer/Makefile.am
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
Reflect changes to bsp.am.
* startup/Makefile.am: Remove -DGDB_MONITOR_ACTIVE (Not used
anywhere).
Add ODS60302_DEBUG conditional.
* include/bsp.h: Fix broken bsp_cat macros (Not compliant to gcc31).
* configure.ac: Add --enable-ods60302-debug.
* configure.in: Remove.
