* clock/ckinit.c, console/console-recording.h, console/console.c,
fatal/bspfatal.c, include/fatal.h, network/network.c,
network/uti596.h, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
* network/network.c: Remove warnings for unused routines left from
original code.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
fatal/Makefile.am, network/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* console/console-recording.c: Remove (rename to console-recording.h).
* console/console-recording.h: New.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* Makefile.am: Misc cleanups and fixes.
* fatal/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* fatal/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console-recording.c, console/console.c,
fatal/bspfatal.c, include/bsp.h, include/coverhd.h, include/fatal.h,
include/page_table.h, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
* console/Makefile.am: Remove BSP_CPPFLAGS.
* configure.ac: Add BSPOPTS PRINTK_MINOR and CONSOLE_MINOR.
* console/Makefile.am: Don't include @RTEMS_BSP@.cfg
fatal/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c: Removed warnings.
* network/network.c, startup/bspclean.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
