* Per PR31, moved mvme16x_hw.h to shared/mvme.
* include/Makefile.am: Modified to reflect movement.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BPSOPTS_*(CD2401_INT_LEVEL).
Add RTEMS_BPSOPTS_*(CD2401_IO_MODE).
Add RTEMS_BPSOPTS_*(CD2401_USE_TERMIOS).
Add AC_DEFINE_UNQUOTED([mvme167]).
* configure.in: Remove.
* network/network.c (uti596_attach): Adjust cpp directives
and conditional braces so all cases compile.
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
wrapup/Makefile.am, network/Makefile.am: Include compile.am
* console.c(_BSP_output_char): Output CR after LF for printk.
* README: Updated
* console/console.c: Fix polled input.
Add support for shared printk.
Add support for more flexible polled I/O with and without termios.
I/O mode and console is selectable either from NVRAM or from
mvme167.cfg. Clean up comments.
* README: Updated
2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* startup/page_table.c (page_table_init): Reorganize NVRAM parameters.
* include/bsp.h: Reorganize NVRAM parameters.
* times: These are the times for the MVME167, not the MBX860-002.
2000-08-11 John Cotton <john.cotton@nrc.ca>
* network/network.c: Fix NVRAM configuration parameter
handling from previous revision.
Check J1-4, restructure NVRAM parameter handling.
* network/network.c: Cleanup of network driver to reduce warnings.
Addition of second parameter to uti596_attach.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
significant things:
and PowerPC
same code base.
John reports this works on the 821 and 860.
significant things:
and PowerPC
same code base.
Gauthier <charles.gauthier@nrc.ca>. The power supply in their
VMEbus cage died so it was submitted at this point. It passes ttcp
which is a really good sign but they would like to do more testing
and cleanup once their hardware is functional again. Please
contact them if you are interested in using or fixing this driver.
As their comments indicate, the performance is actually quite good
even at this point as indicated by the ttcp results.
Please note that this is by no means a final version. The code is still
fairly ugly, and will require some further fixing. On the bright side, what
is attached works. I finally ran the test programs successfully with
optimized code and data cache enabled:
netdemos worked, but failed on the UDP transfer (runs out of buffers).
ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx.
tftp worked
that contains:
* Removes MKLIB
handling)
converted to automake.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
