Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Was including non-existent .h file.
Fixed some warnings.
Reformatted file header comment blocks.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
The application should use confdefs.h to set up the initial user
extensions. The bsp_fatal_error_occurred() handler is available via
<fatal.h>.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c:
* timer/timer.c: Include <rtems/btimer.h>.
* console/console.c: Add BSP_poll_char.
* timer/timer.c: Remove warnings.
* startup/bspclean.c, startup/bspstart.c: Remove warnings.
PR 1479/bsps
* fatal/bspfatal.c: Complete strcat conversion.
* make/custom/mvme167.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme167.cfg: New (relocated from /make/custom).
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* console/console.c, timer/timer.c: Fix warnings and typos.
* console/console.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
PR 1371/bsps
* network/network.c: mvme167 network driver buggy.
PR 1370/bsps
* console/console.c: mvme167 console driver BSP_output_char fails to
convert \n -> \n\r
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
PR 1303/bsps
* fatal/bspfatal.c: strcat() is safe to use even in worst case, so do
not have BSP specific mystrcat().
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
