* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
fatal/Makefile.am, network/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* fatal/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* fatal/Makefile.am: Remove all-local: $(ARCH).
fatal/Makefile.am: Reflect having moved automake.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* fatal/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
wrapup/Makefile.am, network/Makefile.am: Include compile.am
converted to automake.
that converts the no_cpu directory to automake.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
