* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* Makefile.am: Pick up ../mvme167/network/network.c.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* README: Remove references to consolex.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove.
PR 563/bsps
* consolex/consolex.c, consolex/consolex.h, consolex/cTest.c,
consolex/Makefile.am, consolex/README:
Remove (Abandoned).
* consolex/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* consolex/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* consolex/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* Makefile.am: Misc cleanups and fixes.
* Makefile.am: Cosmetics.
* consolex/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* tools/Makefile.am: Cosmetics.
* consolex/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Correct path to mvme16x_hw.h.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* clock/ckinit.c, console/console.c, consolex/cTest.c,
consolex/consolex.c, consolex/consolex.h, include/bsp.h,
include/coverhd.h, include/tod.h, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c,
timer/timerisr.S, tod/tod.c: URL for license changed.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* startup/page_table.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
