* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -11/+11 |
| | | | | | * timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -7/+12 |
| | | | | | * timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-19 | 3 | -5/+5 |
* | 2008-08-19 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-19 | 1 | -0/+5 |
| | | | | | * startup/bspclean.c, timer/timer.c, tod/tod.c: Add missing prototypes. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 2 | -12/+0 |
* | 2008-05-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-05-14 | 2 | -29/+17 |
| | | | | * Makefile.am: Rework to avoid .rel files. | ||||
* | 2008-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-05-12 | 2 | -1/+12 |
| | | | | | | | | | | | | * startup/bspstart.c: Refactored and renamed initialization routines to rtems_initialize_data_structures, rtems_initialize_before_drivers, rtems_initialize_device_drivers, and rtems_initialize_start_multitasking. This opened the sequence up so that bootcard() could provide a more robust and flexible framework which is easier to explain and understand. This also lays the groundwork for sharing the division of available memory between the RTEMS workspace and heap and the C library initialization across all BSPs. | ||||
* | 2008-03-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-03 | 2 | -1/+6 |
| | | | | | * startup/linkcmds: Add wildcard to gcc_except_table section so programs compiled with gcc 4.3.x can link. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 4 | -14/+9 |
| | | | | | | * clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 3 | -18/+6 |
| | | | | | | * include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-03 | 3 | -3/+12 |
| | | | | | | | | | | * Makefile.am, startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 2 | -2/+6 |
| | | | | | * startup/bspstart.c: Eliminate the interrupt_vector_table field in the m68k CPU Table since it is never read. | ||||
* | 2007-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-05-03 | 2 | -2/+6 |
| | | | | * startup/linkcmds: Handle .data.* sections | ||||
* | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-12 | 2 | -5/+6 |
| | | | | * bsp_specs: Remove qrtems_debug. | ||||
* | 2007-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-02 | 3 | -3/+9 |
| | | | | | * Makefile.am, configure.ac: Add dummy printk support so all tests link. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 4 | -2/+10 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-15 | 2 | -1/+6 |
| | | | | | * Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove superfluous -DASM. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 2 | -2/+0 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -2/+6 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -1/+0 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -59/+6 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 1 | -0/+4 |
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+66 |
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 2 | -2/+6 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-18 | 3 | -48/+11 |
| | | | | | * Makefile.am: Use ../../shared/tod.h instead of include/tod.h. * include/tod.h: Remove. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -6/+10 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -88/+26 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-26 | 2 | -1/+6 |
| | | | | * startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 2 | -2/+2 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 4 | -2/+10 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -3/+13 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-22 | 3 | -19/+43 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -10/+5 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -1/+5 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 6 | -7/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 9 | -102/+105 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 2 | -3/+0 |
* | 2004-04-08 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-08 | 2 | -1/+6 |
| | | | | | * mvme162/startup/bspclean.c: Include <rtems/m68k/zilog/z8036.h> instead of <zilog/z8036.h>. | ||||
* | * timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 2 | -1/+5 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -4/+11 |
| | | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. * console/console.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>. |
