Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Conflicts:
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
* console/console.c: char_ready() was never returning true so console
never processed input data
* console/console.c: added printk() support to default device
* include/bsp.h: Added #define for MOT_162BUG_VEC_ADDRESS
* startup/bspclean.c: Modified to use MOT_162BUG_VEC_ADDRESS
* startup/bspstart.c: Modified to use MOT_162BUG_VEC_ADDRESS
* make/custom/mvme162.cfg: Modified to use "RTEMS_CPU_MODEL=68lc040"
and "CPU_CFLAGS = -mcpu=68040 -msoft-float" so BSP will always
work with all board variations.
* README: Added notes on user required configuration changes and
information about board models and variants
* README.models: New file that contains a detailed list of MVME162
models and variants.
Signed-off-by: Vic Hoover <victor.hoover.ctr@navy.mil>
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* Makefile.am: Remove reference to wrapup directory.
* startup/bspclean.c, startup/page_table.c:
* timer/timer.c: Include <rtems/btimer.h>.
* startup/bspclean.c: Remove warnings.
* make/custom/mvme162.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme162lx.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme162.cfg: New (relocated from /make/custom).
* make/custom/mvme162lx.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am: Cosmetics.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c,
startup/linkcmds: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* include/bsp.h, console/console.c, timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
