2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 1 | -97/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2007-01-26 | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use MKDIR_P instead of mkdir_p. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require automake > 1.9. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reworked. | |||||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-10 | 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Cosmetics. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -1/+1 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-04-03 | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.ac: Remove AC_EXEEXT (obsolete). | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+6 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
2000-11-02 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | |||||
2000-10-27 | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
