* | * timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 1 | -1/+1 |
| | | | | | | | | * clock/ckinit.c, console/console.c, consolex/cTest.c, consolex/consolex.c, consolex/consolex.h, include/bsp.h, include/coverhd.h, include/tod.h, startup/bspclean.c, startup/bspstart.c, startup/linkcmds, timer/timer.c, timer/timerisr.S, tod/tod.c: URL for license changed. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+47 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
