output.
* timer/timer.c: Include <rtems/btimer.h>.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/ckinit.c, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
* clock/ckinit.c, console/console.c, consolex/cTest.c,
consolex/consolex.c, consolex/consolex.h, include/bsp.h,
include/coverhd.h, include/tod.h, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c,
timer/timerisr.S, tod/tod.c: URL for license changed.
