* Makefile.am: Misc cleanups and fixes.
* consolex/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* tools/Makefile.am: Cosmetics.
* consolex/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, consolex/cTest.c,
consolex/consolex.c, consolex/consolex.h, include/bsp.h,
include/coverhd.h, include/tod.h, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c,
timer/timerisr.S, tod/tod.c: URL for license changed.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* startup/page_table.c: Removed warnings.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
converted to automake.
and memory layout. Next step is to share the same bsp_pretasking_hook.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
work with m68k-elf on late model versions of binutils (990901+)
without overlapping or missing section errors.
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
<jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me
know what was wrong and I supplied the code. :)
by newlib.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
