* README: Remove references to consolex.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove.
* consolex/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* consolex/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* consolex/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* tools/Makefile.am: Cosmetics.
* consolex/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
converted to automake.
