* consolex/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* tools/Makefile.am: Cosmetics.
* consolex/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network/Makefile.am: Fix improper use of $(srcdir) in VPATH.
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
