path: root/c/src/lib/libbsp/m68k/mvme162/include/page_table.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-27/+0
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill1-19/+0
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2004-04-21Remove stray white spaces.Ralf Corsepius1-9/+12
1995-12-19changes remerged after disk crash -- history lostJoel Sherrill1-0/+3
1995-12-19file lost in crash and re-addedJoel Sherrill1-0/+42
