subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
to lib/include.
four serial ports.
(Sapporo, Japan) submitted the extended console driver for the
MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines.
This device driver supports four serial ports, cooked IO, and
provides a portable base for Zilog 8530 based console drivers.
