path: root/c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (follow)
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-281-45/+0
| | | | | | | PR 563/bsps * consolex/consolex.c, consolex/consolex.h, consolex/cTest.c, consolex/Makefile.am, consolex/README: Remove (Abandoned).
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-211-1/+3
| | | | | | * Makefile.am: Add PREINSTALL_DIRS. * consolex/Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+3
| | | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * consolex/Makefile.am: Ditto. * startup/Makefile.am: Ditto.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+1
| | | | | | * consolex/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-031-10/+11
| | | | | | | | | | | | | * Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * consolex/Makefile.am: Add preinstallation dirstamp support. * network/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * tod/Makefile.am: Cosmetics. * tools/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * consolex/Makefile.am: Remove all-local: $(ARCH). * network/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * tod/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. consolex/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. network/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. tod/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2002-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-211-1/+0
| | | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg. * network/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg. * tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * consolex/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * tools/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * consolex/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * network/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * tod/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-181-3/+4
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * consolex/Makefile.am: Ditto. * include/bsp.h: Include bspopts.h.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * clock/Makefile.am, console/Makefile.am, consolex/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-0/+40
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
