* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* README: Remove references to consolex.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
