path: root/c/src/lib/libbsp/m68k/mvme162/Makefile.in (follow)
* Added TOD driver from Katsutoshi Shibuya.Joel Sherrill1997-10-231-1/+1
* consolex built for all models.Joel Sherrill1997-08-041-8/+4
* Corrected typo.Joel Sherrill1997-08-011-1/+1
* Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd.Joel Sherrill1997-08-011-1/+11
| | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+19
