* startup/linkcmds: Add sections required by newer gcc versions.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* include/bsp.h, shmsupp/getcfg.c, shmsupp/lock.c,
startup/bspstart.c: Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING.
Remove AM_CONDITIONAL(HAS_MP).
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
* include/bsp.h, include/coverhd.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspstart.c, startup/linkcmds: URL for license changed.
