Update #3285.
output.
* timer/timer.c: Include <rtems/btimer.h>.
* startup/bspclean.c, timer/timer.c: Remove warnings.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/ckinit.c, console/console.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size
types.
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
timer/timer.c: URL for license changed.
(Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and
T.N.I. (Brest, France)
