Update #2408.
warning and clean up
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* startup/bspclean.c: Spelling.
* startup/bspclean.c, timer/timer.c: Remove warnings.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c,
startup/linkcmds: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* startup/bspstart.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
* startup/bspclean.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* clock/ckinit.c, console/console.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size
types.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
timer/timer.c: URL for license changed.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
