* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 1 | -8/+0 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -14/+0 |
| | | | | by newlib. | ||||
* | Moved bsp_postdriver_hook() to a shared file and made it a common | Joel Sherrill | 1998-03-30 | 1 | -26/+3 |
| | | | | component. | ||||
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 1 | -18/+1 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 1 | -4/+4 |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+245 |
(Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) |
