path: root/c/src/lib/libbsp/m68k/mvme136 (unfollow)
2015-12-08m68k/mvme136: RemoveAun-Ali Zaidi21-1531/+0
closes #2444.
2015-12-08Add RTEMS linker setsSebastian Huber1-0/+2
Update #2408.
2015-07-16Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guardJoel Sherrill1-2/+2
This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done
2015-03-09Move contents of libcsupport/include/zilog into libbsp/sharedJoel Sherrill2-0/+13
Only a few BSPs use this and it should not have been in libcsupport.
2015-03-09mvme136.cfg: Remove -DNDEBUG flagJoel Sherrill1-1/+1
2014-12-05Update bug report URLSebastian Huber1-1/+1
2014-10-23bsps: Move extern "C" to not cover includesSebastian Huber1-4/+4
2014-10-13m68k/mvme136: Fix warningsJoel Sherrill5-90/+25
2014-10-09m68k/mvme136/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix ↵Joel Sherrill1-10/+5
warning and clean up
2014-09-16Use correct prototype of benchmark_timer_read()Joel Sherrill1-1/+1
This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
2014-08-29Regenerate all preinstall.am files.Chris Johns1-3/+3
With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash.
2014-08-28Regenerate all preinstall.am files.Joel Sherrill1-7/+7
Apparently, at some point automake output changed and these were not updated.
2014-07-16Add More Testsuite Configuration Files and Update Existing OnesJoel Sherrill1-0/+7
The first pass at building these was without networking enabled. This pass addresses that plus accounts for some new BSPs which needed testsuite.tcfg files and BSPs which could not link tests which had been added since the first pass.
2014-04-22bsps: Fix TLS support in linker command filesSebastian Huber1-1/+3
The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section.
2014-03-21mvme136/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill1-16/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns14-14/+14
2014-02-04bsps: Thread-local storage (TLS) for linkcmdsSebastian Huber1-0/+18
2014-01-14libbsp m68k: Add Doxygen file header to coverhd.hCynthia Rempel1-1/+7
2014-01-09libbsp tm27.h: Add Doxygen file header to all tm27.hCynthia Rempel1-2/+6
2013-12-03m68k: refactored shared/start.S to shared/start/start.SDaniel Ramirez1-1/+1
2013-08-09Use $(EXEEXT) [defaults to "exe"] to generate binariesNick Withers1-1/+1
2013-03-08RTEMS: Delete ChangeLog files.Gedare Bloom1-619/+0
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
2012-12-07score: rtems_initialize_start_multitasking()Sebastian Huber1-7/+0
Do not return from rtems_initialize_start_multitasking() and call rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and a fatal code with the exit status. Remove all bsp_cleanup() functions. The boot_card() is now a no return function.
2012-11-15score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber2-2/+12
Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
2012-11-14bsps: Include <bsp/bootcard.h>Sebastian Huber1-2/+1
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix bsp_cleanup() definition if necessary.
2012-08-06Revert "Add bspopts.h.in."Gedare Bloom1-31/+0
This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
2012-07-19Require automake-1.12.2.Ralf Corsépius1-1/+1
2012-07-19Require autoconf-2.69.Ralf Corsépius1-1/+1
2012-05-24Add bspopts.h.in.Ralf Corsépius1-0/+31
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill18-38/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill2-0/+6
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius2-6/+0
2012-04-16m68k: use shared setvec.cGedare Bloom1-1/+1
2012-04-16m68k: replace m68k_isr with rtems_isrGedare Bloom2-4/+4
2012-02-01Remove all .cvsignore files.Joel Sherrill2-12/+0
2011-07-132011-07-13 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2-1/+11
PR 1824/cpukit * startup/bspclean.c: Return exit/shutdown status back to boot_card(). boot_card() propagates this to bsp_cleanup() and returns it to the assembly that started the application. bsp_cleanup() prototype changed.
2011-02-112011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius4-8/+13
* include/bsp.h, shmsupp/lock.c, startup/bspclean.c: Use "__asm__" instead of "asm" for improved c99-compliance.
2011-02-092011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+7
* timer/timer.c: Include <rtems/btimer.h>. Fix benchmark_timer_read() definition.
2011-02-022011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
2010-04-282010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2-2/+6
* startup/bspclean.c: Remove warnings.
2009-11-28Whitespace removal.Ralf Corsepius1-1/+1
2009-10-212009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-3/+4
* make/custom/mvme136.cfg: Remove RTEMS_BSP_FAMILY.
2009-10-202009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+5
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-0/+35
* make/custom/mvme136.cfg: New (relocated from /make/custom).
2009-09-152009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+5
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
2009-07-162009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+8
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
2008-12-042008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-2/+8
* bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19.
2008-09-302008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-15/+5
* timer/timer.c: Eliminate uses of old benchmark timer names.
2008-09-302008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-7/+9
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules.
2008-09-292008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-10/+19
* Makefile.am: Eliminate *_SOURCES.
