* mvme136/clock/ckinit.c, mvme136/startup/bspclean.c,
mvme136/startup/bspstart.c, mvme136/timer/timer.c: Include
<rtems/m68k/zilog/z8036.h> instead of <zilog/z8036.h>.
* startup/bspclean.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* clock/ckinit.c, include/bsp.h, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING.
Remove AM_CONDITIONAL(HAS_MP).
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
shmsupp/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
