* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 4 | -14/+9 | |
| | | | | | | * clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | |||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 3 | -18/+6 | |
| | | | | | | * include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | |||||
* | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-03 | 3 | -4/+14 | |
| | | | | | | | | | | * Makefile.am, startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | |||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 2 | -1/+5 | |
| | | | | | * startup/bspstart.c: Eliminate the interrupt_vector_table field in the m68k CPU Table since it is never read. | |||||
* | 2007-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-05-03 | 2 | -2/+6 | |
| | | | | * startup/linkcmds: Handle .data.* sections | |||||
* | 2007-05-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-05-01 | 2 | -4/+27 | |
| | | | | * Makefile.am: Minor rework to shrink minimum size to <48K. | |||||
* | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-12 | 2 | -5/+6 | |
| | | | | * bsp_specs: Remove qrtems_debug. | |||||
* | 2007-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-02 | 2 | -1/+5 | |
| | | | | * Makefile.am: Add dummy printk support so all tests link. | |||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 | |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 | |
| | | | | * configure.ac: New BUG-REPORT address. | |||||
* | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-15 | 2 | -1/+6 | |
| | | | | | * Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | |||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -1/+5 | |
| | | | | * Makefile.am: Remove superfluous -DASM. | |||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 | |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 2 | -2/+0 | |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -2/+6 | |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | |||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 | |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 | |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 | |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 | |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -1/+0 | |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -47/+6 | |
| | | | | * Makefile.am: Add preinstall.am. | |||||
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+54 | |
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 2 | -2/+6 | |
| | | | | * include/bsp.h: New header guard. | |||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -5/+9 | |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -75/+24 | |
| | | | | * Makefile.am: Remove build-variant support. | |||||
* | 2004-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-26 | 2 | -1/+6 | |
| | | | | * startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*. | |||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 | |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 | |
| | | | | * configure.ac: Require automake > 1.9. | |||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -4/+13 | |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-22 | 3 | -16/+41 | |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -10/+5 | |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -1/+5 | |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 3 | -4/+0 | |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 4 | -15/+15 | |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 | |
* | 2004-04-08 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-08 | 5 | -4/+10 | |
| | | | | | | * mvme136/clock/ckinit.c, mvme136/startup/bspclean.c, mvme136/startup/bspstart.c, mvme136/timer/timer.c: Include <rtems/m68k/zilog/z8036.h> instead of <zilog/z8036.h>. | |||||
* | * timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 2 | -1/+5 | |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -4/+11 | |
| | | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * startup/bspclean.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | |||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 8 | -26/+32 | |
| | | | | | | * clock/ckinit.c, include/bsp.h, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | |||||
* | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -2/+35 | |
| | | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 2 | -1/+5 | |
| | | | | * Makefile.am: Reflect changes to bsp.am. | |||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+5 | |
| | | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE. | |||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -2/+8 | |
| | | | | | * Makefile.am: Pickup files from ../../m68k/shared instead of ../shared. Reformat. | |||||
* | 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-03 | 2 | -4/+5 | |
| | | | | | * configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING. Remove AM_CONDITIONAL(HAS_MP). | |||||
* | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-29 | 2 | -1/+5 | |
| | | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. | |||||
* | .cvsignore: Remove Makefile* | Ralf Corsepius | 2004-01-28 | 1 | -2/+0 | |
* | Remove .cvsignore | Ralf Corsepius | 2004-01-28 | 6 | -12/+0 | |
* | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-28 | 9 | -211/+122 | |
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 3 | -2/+9 | |
| | | | | | * Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu. | |||||
* | 2004-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-20 | 2 | -2/+6 | |
