path: root/c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+48
