* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
