that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
that converts the no_cpu directory to automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
