PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* include/bsp.h, shmsupp/lock.c, startup/bspclean.c:
* timer/timer.c: Include <rtems/btimer.h>.
* startup/bspclean.c: Remove warnings.
* make/custom/mvme136.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme136.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* console/console.c, include/bsp.h: Remove unnecessary boilerplate
comments. Eliminate use of EXTERN and move unnneccessarily global
variables to console.c.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, clock/ckinit.c, startup/bspstart.c, startup/linkcmds:
Add use of bsp_get_work_area() in its own file and rely on BSP
Framework to perform more initialization. Remove unnecessary includes
of rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* console/console.c, timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* startup/bspclean.c, timer/timer.c: Add missing prototypes.
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can dirty the
work area memory. Until most/all BSPs support this new capability, if
the BSP supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* startup/linkcmds: Handle .data.* sections
* Makefile.am: Minor rework to shrink minimum size to <48K.
* bsp_specs: Remove qrtems_debug.
* Makefile.am: Add dummy printk support so all tests link.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* startup/linkcmds: Add sections required by newer gcc versions.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
